Zum Hauptinhalt wechseln
Englisch
Deutsch
3. Schritt
Insert a black plastic spudger or safe-open pry tool between the bezel and the rear housing of the screen. Work your way around the sides and top of the screen, carefully separating the bezel from the housing. If you pry recklessly, you will break off the tabs that hold the bezel to the frame.
  • Insert a black plastic spudger or safe-open pry tool between the bezel and the rear housing of the screen.
  • Work your way around the sides and top of the screen, carefully separating the bezel from the housing.
  • If you pry recklessly, you will break off the tabs that hold the bezel to the frame.
  • Finally, pry the bottom portion of the bezel free of the back housing.
Hier Übersetzung einfügen
