Zum Hauptinhalt wechseln
Englisch
Deutsch
6. Schritt
The LCD connector is taped into its socket. Use tweezers to carefully lift the clear tape holding the connector down. Once you peel the tape past the gold portion of the connector, the connector should pull out easily.
  • The LCD connector is taped into its socket.
  • Use tweezers to carefully lift the clear tape holding the connector down.
  • Once you peel the tape past the gold portion of the connector, the connector should pull out easily.
  • If you purchased a replacement LCD with the metal brackets pre-attached, then you are finished. If not, continue reading!
Hier Übersetzung einfügen
