Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Pinch the top and bottom edges of the panel and pull it away from the RAZR2. The rear panel uses four small hooks to hold it in place.  If the panel will not easily pull away, slide the panel more toward the hinge. The rear panel uses four small hooks to hold it in place.  If the panel will not easily pull away, slide the panel more toward the hinge.
  • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
  • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
Hier Übersetzung einfügen
