Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Use a spudger to remove the Wifi antenna from the device by carefully prying it up off the casing. The Wifi antenna is attached to the device by a mild adhesive. Once the antenna is free from the adhesive, set the antenna off to the side.
  • Use a spudger to remove the Wifi antenna from the device by carefully prying it up off the casing.
  • The Wifi antenna is attached to the device by a mild adhesive. Once the antenna is free from the adhesive, set the antenna off to the side.
  • Do not try to detach the antenna from the motherboard.
Hier Übersetzung einfügen
