Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
7. Schritt
Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing. Carefully lift the motherboard off. The piece marked in the third image may be loose and fall out freely.  If it does not fall off, use your fingers or a plastic opening tool to snap it off.  Make sure to place it under the motherboard during reassembly, as found in the image.
  • Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
  • Carefully lift the motherboard off.
  • The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
Hier Übersetzung einfügen
