Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use a spudger to pry the two white tabs off the edge of the metal frame.  This will separate the front cover from the metal frame. Use a spudger to break the adhesive holding the front cover onto the screen by sliding it slowly around the edges just underneath the front cover. Do not attempt to remove the metal frame of the screen from the front cover until all adhesive as been separated between the front cover and the screen.
  • Use a spudger to pry the two white tabs off the edge of the metal frame. This will separate the front cover from the metal frame.
  • Use a spudger to break the adhesive holding the front cover onto the screen by sliding it slowly around the edges just underneath the front cover.
  • Do not attempt to remove the metal frame of the screen from the front cover until all adhesive as been separated between the front cover and the screen.
Hier Übersetzung einfügen
