Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 4
Once the riser main hits the bottom, turn the T-handle while pushing down. This will hook the foot valve onto the traveling valve, allowing you to pull the two out of the well together. You should feel some resistance if the foot valve is successfully attached.
  • Once the riser main hits the bottom, turn the T-handle while pushing down.
  • This will hook the foot valve onto the traveling valve, allowing you to pull the two out of the well together.
  • You should feel some resistance if the foot valve is successfully attached.
Hier Übersetzung einfügen
