Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Lift the slider and riser main pipe. Place a pump rod clamp around the rod, and tighten it securely against the pump rod. Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  • Lift the slider and riser main pipe.
  • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
  • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
Hier Übersetzung einfügen
