Englisch
Deutsch
8. Schritt
Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board Disconnect the antenna connector cable from the USB board.
  • Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board
  • Disconnect the antenna connector cable from the USB board.
Trenne das Kabel der Softtaste von dem USB Board Kabel. Sei hier besonders vorsichtig; sobald du das Kabel entfernt hast, ziehe es von der USB Platine weg.
Trenne das Verbindungskabel der Antenne von der USB Platine.
