Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger. Insert a spudger under the cover, then pry it up and away from the device. Remove the rear plastic cover from the iPod.
  • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
  • Insert a spudger under the cover, then pry it up and away from the device.
  • Remove the rear plastic cover from the iPod.
  • Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
Hier Übersetzung einfügen
