Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use the flat end of a spudger to push the home button gasket toward the center of the button to release the light adhesive. Work your way around the home button in this manner until you can easily remove the button from the front glass.
  • Use the flat end of a spudger to push the home button gasket toward the center of the button to release the light adhesive.
  • Work your way around the home button in this manner until you can easily remove the button from the front glass.
  • To prevent tearing the gasket around the home button, do not pry the home button out until the adhesive has been sufficiently loosened.
Hier Übersetzung einfügen
