Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 12
If you see bulged capacitors, treat the power supply as if the capacitors are holding a residual charge. If the filter capacitor is replaced, it MUST be discharged before removal. In addition, the black screw (Blue marker) is a grounding screw and cannot be lost. Only lift the power supply board at a slight angle. Lifting it any higher may damage the processing board or interface.
Remove the power supply
  • If you see bulged capacitors, treat the power supply as if the capacitors are holding a residual charge.
  • If the filter capacitor is replaced, it MUST be discharged before removal. In addition, the black screw (Blue marker) is a grounding screw and cannot be lost.
  • Only lift the power supply board at a slight angle. Lifting it any higher may damage the processing board or interface.
  • If you cannot find the original capacitors, the original parts can be safely substituted.
  • This capacitor is only used on older revisions. If your board has this capacitor, it should be replaced if handy.
  • With the power supply shield removed from the monitor, identify the power supply. Along with the listed capacitors, take note of any others you want to replace (Ex: Inverter coil).
  • Remove the 4 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis mounting holes.
Hier Übersetzung einfügen
