Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Starting from the SIM slot side, carefully peel the back cover off of the phone. The back cover is very flexible, but you don't want to damage any internal components by being too hasty. There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
  • Starting from the SIM slot side, carefully peel the back cover off of the phone.
  • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
  • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
  • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
  • The flash cable is attached on the power/volume button side of the phone.
Beginne an der Seite mit dem SIM Karten Einschub vorsichtig die Rückabdeckung vom Gerät abzulösen.
Die Rückabdeckung ist sehr biegsam, du willst aber sicher keine der inneren Bauteile durch zu große Ungeduld beschädigen.
Löse die Rückabdeckung noch nicht ganz ab, sie ist immer noch mit dem Smartphone durch das Kabel zum Kamerablitz verbunden.
Das Kabel ist an der Seite des Smartphones mit der Einschalttaste/Lautstärkeregelung befestigt.
[* black] Starting from the SIM slot side, carefully peel the back cover off of the phone.
[* icon_note] The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
[* icon_caution] There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
[* icon_caution] '''Do not''' separate the back cover entirely; it is still connected to the phone by the camera flash cable.
[* icon_note] The flash cable is attached on the power/volume button side of the phone.
