Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on. The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover. Do not push the opening tool deep into phone, or you may damage internal components.
  • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
  • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
  • Do not push the opening tool deep into phone, or you may damage internal components.
Schiebe das Werkzeug vorsichtig entlang der Seite des Smartphones mit den Tasten.
Der Kunststoff der vorderen Abdeckung ist hier dünner und die Tasten können sich bewegen; arbeite langsam, um Schäden an den Tasten oder der Frontabdeckung zu vermeiden.
[* black] Carefully slideRun the opening tool along the button side ofseam around all four sides, separating the phoneremaining clips holding the cover on.
[* icon_caution] The plastic on the front cover is thinner herenear the buttons, and the buttons may move around; goaround. Go slowly to avoid damaging the buttons or the front cover.
[* icon_caution] Do not push the opening tool deep into phone, or you may damage internal components.
