Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 35 übersetzen
Schritt 35
If this is your first time applying thermal paste, I recommend using a quality thermal paste brand like Arctic Silver and reading a guide here on iFixit. With the motherboard out, turn it upside down on a static free surface. To remove the heatsink and replace thermal paste, remove the screws in the correct order (marked with a number on the heatsink).
Remove heat sink and apply thermal paste
  • If this is your first time applying thermal paste, I recommend using a quality thermal paste brand like Arctic Silver and reading a guide here on iFixit.
  • With the motherboard out, turn it upside down on a static free surface.
  • To remove the heatsink and replace thermal paste, remove the screws in the correct order (marked with a number on the heatsink).
  • Clean old thermal paste with isopropyl alcohol. Ensure that after applying thermal paste it doesn't leak onto the motherboard (if it's on the green square, it's fine).
  • When putting the heat sink back on, try to have the screw holes align on your first try. This is to maintain an even spread of the thermal paste.
  • Rescrew in the correct order (refer to the numbers on the heat sink).
  • Tighten each screw one at a time to end up with good heat dissipation.
Hier Übersetzung einfügen
