Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 35 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work. To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
  • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Gently pry the digitizer connector up from its socket on the logic board.
Hebele mit einem Plastiköffungswerkzeug vorsichtig den Verbinder des Digitizers aus seinem Sockel auf dem Logic Board.
Sei dabei vorsichtig und hebele gleichmäßig am Verbinder, keinesfalls am Sockel. Die beiden sind sehr empfindlich und wenn du eines davon beschädigst funktioniert dein Digitizer nicht mehr.
[* black] Use a plastic opening tool to gently pry the digitizer connector up from its socket on the logic board.
icon_caution] Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
[* black] To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
[* black] Gently pry the digitizer connector up from its socket on the logic board.
