Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
5. Schritt
The 3.5 mm Phillips screw indicated below with a red circle may be absent in some models.
  • The 3.5 mm Phillips screw indicated below with a red circle may be absent in some models.
  • Remove the following 5 screws and 3 nuts from the heat sink:
  • One 3.5 mm Phillips from the lower left corner of the heat sink.
  • Three 6 mm Phillips from around the fan.
  • One 7.5 mm Phillips at the top right corner of the heat sink.
  • One 4 mm nut from the side of the heat sink.
  • Two 4 mm screw nuts with attached springs from either side of the heat sink.
Hier Übersetzung einfügen
