Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely. Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
  • With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
  • Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
Hier Übersetzung einfügen
