Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Disconnect the communications power cable from its socket (labeled J50 in the service manual). Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently. Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
  • Disconnect the communications power cable from its socket (labeled J50 in the service manual).
  • Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
Hier Übersetzung einfügen
