Englisch
Deutsch
2. Schritt
Start by flipping the laptop on its front cover. As you can see from mine, it's not difficult to scratch up the surface so I'd recommend putting a cloth or cupboard protector underneath The first step is to remove the middle section housing the hard drive, wireless card, and ram
  • Start by flipping the laptop on its front cover. As you can see from mine, it's not difficult to scratch up the surface so I'd recommend putting a cloth or cupboard protector underneath
  • The first step is to remove the middle section housing the hard drive, wireless card, and ram
  • BEFORE YOU START - Make sure the battery is removed, and the unit is unplugged. It's also advised to wear an anti-static wrist strap or at least ground yourself
  • There are 5 anchored screws (they don't come all the way out) that need to be loosened
  • There is a small ridge just below the battery that helps in removing the cover. I used a spudger but if you don't have one, a small flathead screwdriver will work. Or a hard guitar pick.
  • Pry from the top - you'll notice small clips on the edges that hold it in place. They may require a little bit of force. Once you get to the bottom, just pull north as the clips on the bottom are larger.
Hier Übersetzung einfügen
