Englisch
Deutsch
10. Schritt
We are almost done with the top of the motherboard - just slide the two opposite-colored connectors south. May need a little wiggle to convince them fully. We will now attempt to start lifting the motherboard - DON'T USE PRESSURE! We still have cables from the bottom to remove Start by putting your lifting tool between the casing and the bottom of the motherboard - you have to "lift" it off this peg to be able to move it further
  • We are almost done with the top of the motherboard - just slide the two opposite-colored connectors south. May need a little wiggle to convince them fully.
  • We will now attempt to start lifting the motherboard - DON'T USE PRESSURE! We still have cables from the bottom to remove
  • Start by putting your lifting tool between the casing and the bottom of the motherboard - you have to "lift" it off this peg to be able to move it further
  • Grab the far right side of the board and start lifting straight up about a "quarter-inch" - it will expose the bottom motherboard connections
Hier Übersetzung einfügen
