Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Unscrew the three Phillips screws from the handle and speaker component. Remove the handle from the door panel so that you can remove the cable. You can pull out the cable from the back of the handle by pulling back on the housing cable, and rotating the cable counter-clockwise in the socket so that it lines up with the opening as to be pulled out.
  • Unscrew the three Phillips screws from the handle and speaker component.
  • Remove the handle from the door panel so that you can remove the cable.
  • You can pull out the cable from the back of the handle by pulling back on the housing cable, and rotating the cable counter-clockwise in the socket so that it lines up with the opening as to be pulled out.
Hier Übersetzung einfügen
