Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
In order to remove the lock actuator with ease, the guide rail for the window nearest the actuator must be moved. The bolt for the guide rail is located on the bottom of the door and uses a 10mm socket.
  • In order to remove the lock actuator with ease, the guide rail for the window nearest the actuator must be moved.
  • The bolt for the guide rail is located on the bottom of the door and uses a 10mm socket.
  • Once the bolt is removed the guide needs to be moved towards the opening in the door. This is done by grabbing the guide and pulling up and towards you.
Hier Übersetzung einfügen
