Englisch
Deutsch
4. Schritt
Once the bottom connector is loosed, you can take away the sound board and separate the flat cable from underneath. Next, the power button has to be removed. It is a bit sticky, so you may want to use a cutter or knife to separate. Long nails also work.
  • Once the bottom connector is loosed, you can take away the sound board and separate the flat cable from underneath.
  • Next, the power button has to be removed. It is a bit sticky, so you may want to use a cutter or knife to separate. Long nails also work.
Hier Übersetzung einfügen
