Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
If you have a floppy disk drive, it has a ribbon cable that runs over the heat-sink assembly that must be moved out of the way.  To remove it, first unplug it from the system board by pulling on plastic pull ring.
Remove the ribbon cable for the floppy disk drive
  • If you have a floppy disk drive, it has a ribbon cable that runs over the heat-sink assembly that must be moved out of the way. To remove it, first unplug it from the system board by pulling on plastic pull ring.
  • The ribbon cable is fastened to the heat-sink assembly with four clips. Simply slide the ribbon cable out from under these clips and move the cable out of the way.
Hier Übersetzung einfügen
