Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
CAUTION: Even though the heat-sink assembly has a protective plastic covering, be careful when touching it -- the assembly may still be hot if your PC was just on.
Remove the Heat Sink
  • CAUTION: Even though the heat-sink assembly has a protective plastic covering, be careful when touching it -- the assembly may still be hot if your PC was just on.
  • Release the blue plastic secure lever under the heat-sink assembly by pushing the tab and pivoting the lever down and away from the assembly.
  • Remove the two screws located at the top and bottom of the heat-sink assembly using a standard Phillips-head screwdriver.
  • Pull the heat-sink assembly off the board as if it were a door with its hinges on the right.
  • Clean the old thermal paste from the contact points on the heat sink
Hier Übersetzung einfügen
