Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 10
Use screwdriver to pry out the vibrating motor. Please be noted the motor is adhered to the front chassis and connected with the power button. Please lift it up carefully to avoid damaging the power button cable. Use screwdriver to pry out the vibrating motor. Please be noted the motor is adhered to the front chassis and connected with the power button. Please lift it up carefully to avoid damaging the power button cable.
  • Use screwdriver to pry out the vibrating motor. Please be noted the motor is adhered to the front chassis and connected with the power button. Please lift it up carefully to avoid damaging the power button cable.
Mit dem Schraubenzieher den Vibrationsmotor entfernen. Vorsicht hierbei, da der Motor mit dem Vordergehäuse sowie dem Einschaltknopf verbunden ist. Vorsichtig den Motor anheben, um eine Beschädigung des Kabels für den Einschaltknopf zu vermeiden.
