Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8 übersetzen
8. Schritt
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base. Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin. Continue turning the gear until completely removed from the blade-shaft.
  • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
  • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
  • Continue turning the gear until completely removed from the blade-shaft.
Hier Übersetzung einfügen
