Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Pry the four feet with the pick-end of the spudger.  These are glued down, so this may require some force. Remove the 6mm PH1 screws located under each foot. Remove the 6mm PH1 screws located under each foot.
  • Pry the four feet with the pick-end of the spudger. These are glued down, so this may require some force.
  • Remove the 6mm PH1 screws located under each foot.
Hier Übersetzung einfügen
