Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out. Repeat until all eight batteries are removed.
  • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
  • Repeat until all eight batteries are removed.
  • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Hier Übersetzung einfügen
