Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment. Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
  • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
Hier Übersetzung einfügen
