Englisch
Deutsch
Schritt 14 übersetzen
14. Schritt
Place the solar panel on a surface that you can solder on.
  • Place the solar panel on a surface that you can solder on.
  • Cut the two wires connecting the circuit board to the solar panel at the base near the solar panel using wire cutters.
  • Take out your Soldering Station. With your new solar panel, solder each lead back to the circuit board, ensuring the positive and negative leads match up correctly as displayed in the photo. Refer to the Repairing Soldered Connection Guide.
  • Put the device back together following the same guide in reverse order.
  • When you reach step 8, apply your Evo-Stick Super Glue along the edges of the plastic panel.
  • Press the panel back into place on the device. Let it sit to dry for 24 hours before use.
  • Enjoy your working device!
Hier Übersetzung einfügen
