Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit. Note: You may use your hands for additional force to separate the two pieces of the outer shell. Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
  • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Hier Übersetzung einfügen
