Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Removing the metal backplate is simple.  This is just stuck on with some flexible glue. So prise something under and off it pops. Inside you can see a number of large cut outs in the rear of the plastic casing.
  • Removing the metal backplate is simple. This is just stuck on with some flexible glue. So prise something under and off it pops.
  • Inside you can see a number of large cut outs in the rear of the plastic casing.
  • Note the small pinhole in the metal backplate that aligns with the rubber sealed hole in the plastic casing - more on that later.
  • There is also a very small ground out area inside the metal backplate that appears to align with the rotating mass of the vibrator.
Hier Übersetzung einfügen
