Zum Hauptinhalt wechseln
Englisch
Deutsch
9. Schritt
Using a wide pry tool, like this trim removal tool, go around the edge of the panel between it and the metal part of the door. You will find it held in place by plastic clips. Gently pry each clip out all the way around. On an older car like the W123, there will likely be some broken clips. Some times, panels are being held in place by only two or three clips.
  • Using a wide pry tool, like this trim removal tool, go around the edge of the panel between it and the metal part of the door. You will find it held in place by plastic clips. Gently pry each clip out all the way around.
  • On an older car like the W123, there will likely be some broken clips. Some times, panels are being held in place by only two or three clips.
  • Be aware that even though there should be no screws holding the panel to the door at this point, you will want to carefully check that someone didn't use a screw in the past to make up for broken clips. If you try and pull it off without removing the screw, you could damage your panel.
Hier Übersetzung einfügen
