Zum Hauptinhalt wechseln
Englisch
Deutsch
8. Schritt
For doors with manual windows, you will need to remove the crank before removing the panel. Use a finger to push the tab that holds the trim piece to the crank out until it clears the crank. Pull trim toward the knob on the crank to release the trim.
  • For doors with manual windows, you will need to remove the crank before removing the panel.
  • Use a finger to push the tab that holds the trim piece to the crank out until it clears the crank.
  • Pull trim toward the knob on the crank to release the trim.
  • The trim piece will release from the peg at the base of the crank. The crank will now slide off.
  • When reassembling the manual window crank, make sure the tapered end of the washer is facing away from the door.
  • The tapered washer is sometimes missing. It is used to protect the panel from wear.
Hier Übersetzung einfügen
