Englisch
Deutsch
6. Schritt
The master vacuum switch can now be detached from the door. To do this, remove the two Philips head screws holding the switch to the door (picture shows screws already removed). Remove the metal bracket the screws were holding and set it aside. Pull the switch gently towards you until you can then slip off the linkage that connects the switch to the lock mechanism.
  • The master vacuum switch can now be detached from the door. To do this, remove the two Philips head screws holding the switch to the door (picture shows screws already removed). Remove the metal bracket the screws were holding and set it aside.
  • Pull the switch gently towards you until you can then slip off the linkage that connects the switch to the lock mechanism.
Hier Übersetzung einfügen
