Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 32 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8
Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them. Pull the plastic nub to release the vacuum seal on the suction cup.
  • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
  • Pull the plastic nub to release the vacuum seal on the suction cup.
  • Remove the suction cup from the screen.
Versuche nicht, die Display Einheit vollständig vom hinteren Gehäuse zu lösen, da beide immer noch durch mehrere Flachbandkabel verbunden sind.
Ziehe an an der Kunststoffnoppe, um das Vakuum des Saugnapfes zu öffnen.
Entferne den Saugnapf von der Display Einheit.
[* icon_caution] Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
[* black] Pull the plastic nub to release the vacuum seal on the suction cup.
[* black] Remove the suction cup from the display assemblyscreen.
