Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
  • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
Ziehe den innersten Streifen gerade nach oben.
Verdrehe den Streifen nicht; versuche den Klebestreifen so flach und ausgebreitet wie möglich zu halten. Wenn der Kleber zusammenfällt, kann er reißen.
Stelle sicher, dass der Streifen an keiner Stelle das Mobiltelefons berührt. Sie könnten den Kleber durchstechen und den Streifen reißen.
[* black] Pull the innermost tab evenly straight up.
icon_caution] Do not twist the tab; tryTry to keep the adhesive strip asstrips flat and wide as possible. When the adhesive bunches up it tends to tearunwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
[* icon_caution] Be sure you do notblack] Slowly pull the tab against anyone of the componentsbattery adhesive strips away from the battery, toward the bottom of the phone, they may punctureiPhone.
[* black] Pull steadily, maintaining constant tension on
the adhesivestrip as it slips out from between the battery and causethe rear case. For best results, pull the strip to tearat a 60º angle or less.
