Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on the corner of the battery or on any of the other internal iPhone components. The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
  • Guide the strip carefully around the corner and up the side of the battery.
  • Be careful not to snag it on the corner of the battery or on any of the other internal iPhone components.
  • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
Ziehe den Streifen vorsichtig und gerade um die Ecke des Akkus.
Ziehe den Streifen weg von dem Akku, wenn du um die Ecke gehst, um die scharfe Kante zu vermeiden.
Ziehe den Streifen entlang des Akkus ab, bis er sich vom Mobiltelefon löst.
[* black] PullGuide the tabstrip carefully and evenly around the corner and up the side of the battery.
[* icon_note] Pull
[* icon_caution] Be careful not to snag it on
the tab away fromcorner of the battery as you roundor on any of the corner to avoid the sharp cornerother internal iPhone components.
[* black] Pullicon_note] The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip along the side ofnear the battery if necessary, until the entire strip comes free from the phonefree.
[* icon_note] Pull
