Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Carefully pry out insert using the small gaps at the front. You can use a small flat screwdriver to do this. Remove the phillips screw and put the trim and insert aside.
Remove Existing Door Handle Trim
  • Carefully pry out insert using the small gaps at the front. You can use a small flat screwdriver to do this.
  • Remove the phillips screw and put the trim and insert aside.
  • Be careful removing the insert, it is easy to damage with the screwdriver.
Hier Übersetzung einfügen
