Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Insert your finger underneath the speaker piece and pry away from the phone body. The plastic layer containing the LCD screen and speaker takes some force to remove. There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
  • Insert your finger underneath the speaker piece and pry away from the phone body.
  • The plastic layer containing the LCD screen and speaker takes some force to remove.
  • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
  • The LCD and the speaker are attached to the same piece and must be replaced together.
Hier Übersetzung einfügen
