Englisch
Deutsch
7. Schritt
Loosen and remove the two 10mm nuts that hold the regulator's pegs in to the door shell. Loosen and remove the 10mm bolt that holds the final connection point of the regulator to the door shell. With these nuts and bolts removed the regulator is now loose from the door but more needs to be done before it can be removed fully.
  • Loosen and remove the two 10mm nuts that hold the regulator's pegs in to the door shell.
  • Loosen and remove the 10mm bolt that holds the final connection point of the regulator to the door shell.
  • With these nuts and bolts removed the regulator is now loose from the door but more needs to be done before it can be removed fully.
Hier Übersetzung einfügen
