Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 2
Once removed, inspect the regulator. The primary metal structure of the regulator should be relatively flat/straight. Inspect it for bends. Inspect the teeth on the large regulator gear and on the small motor gear for uneven wear or broken teeth. On this particular regulator used in this example you can see it is very obviously bent away from the motor. This is causing the large gear to rub against the motor body in two places. This explains the slow movement of the window even after greasing the felt slides on the window rails; the friction of the gear rubbing on the motor housing is stressing the motor.
  • Once removed, inspect the regulator. The primary metal structure of the regulator should be relatively flat/straight. Inspect it for bends. Inspect the teeth on the large regulator gear and on the small motor gear for uneven wear or broken teeth.
  • On this particular regulator used in this example you can see it is very obviously bent away from the motor.
  • This is causing the large gear to rub against the motor body in two places. This explains the slow movement of the window even after greasing the felt slides on the window rails; the friction of the gear rubbing on the motor housing is stressing the motor.
  • The teeth on the gears and motor showed some wear but still appeared serviceable and none of the teeth were broken. If this was not the case the process would need to stop here while a good used regulator was sourced.
Wenn er ausgebaut ist, dann schaue dir den Fensterheber genau an. Der Hauptträger aus Metall muss ziemlich flach/gerade sein. Er darf nicht verbogen sein. Schaue dir die Zähne am großen Zahnrad und am kleinen Zahnrad am Motor an, ob Zähne fehlen oder ungleichmäßig abgenutzt sind.
Bei dem hier gezeigten Fensterheber ist der Träger offensichtlich vom Motor weg gebogen.
Dadurch reibt das große Zahnrad an zwei Stellen am Motor. Es erklärt auch die langsame Bewegung des Fensters, obwohl die Filze in den Schienen geschmiertvwurden. Die Reibung des Zahnrads am Motor belastet diesen zusätzlich.
Die Zähne am Motor und am Zahnrad waren zwar ein wenig abgenutzt, funktionierten aber noch. Keines fehlte. Wenn das nicht so wäre, dann hätte der Fensterheber ersetzt werden müssen.
