Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Once the charger connector is pulled out, proceed with removing the logic board. To remove the logic board, grip the four corners of the logic board and lift from the front inner case.
  • Once the charger connector is pulled out, proceed with removing the logic board.
  • To remove the logic board, grip the four corners of the logic board and lift from the front inner case.
  • Notice the second picture the logic board has been turned over with the button side facing up.
  • Note: Upon reassembly the logic board must be placed correctly. The button side with the various circles should face down, lining up with the circular holes on the inner case.
Hier Übersetzung einfügen
