Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Once the charger connector is pulled out, proceed with removing the logic board. To remove the logic board, grip the four corners of the logic board and lift from the front inner case.
  • Once the charger connector is pulled out, proceed with removing the logic board.
  • To remove the logic board, grip the four corners of the logic board and lift from the front inner case.
  • Notice the second picture the logic board has been turned over with the button side facing up.
  • Note: Upon reassembly the logic board must be placed correctly. The button side with the various circles should face down, lining up with the circular holes on the inner case.
Hier Übersetzung einfügen
