Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 8
Time to remove the iron part. Pull out the fan wire. If you need you can use a flat screwdriver, paying attention not to break it. It's time to detach the SATA adapters with the fan, so you can contemplate the main circuit.
  • Time to remove the iron part.
  • Pull out the fan wire. If you need you can use a flat screwdriver, paying attention not to break it.
  • It's time to detach the SATA adapters with the fan, so you can contemplate the main circuit.
  • Don't remove the battery as this could lead to time loss, some basic (board-level) settings, and unwanted resets.
Hier Übersetzung einfügen
