Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
To begin you will need to remove your door panel. For help with this process see the door panel removal guide. Then you will need to remove the master door lock switch from the car. After following the steps in the vacuum door lock system diagnosis technique guide to unbolt the switch from the door and disconnect it from the lock mechanism simply pull the three vacuum lines, making note of where the red, green, and solid yellow lines attach.
  • To begin you will need to remove your door panel. For help with this process see the door panel removal guide.
  • Then you will need to remove the master door lock switch from the car. After following the steps in the vacuum door lock system diagnosis technique guide to unbolt the switch from the door and disconnect it from the lock mechanism simply pull the three vacuum lines, making note of where the red, green, and solid yellow lines attach.
Hier Übersetzung einfügen
