Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Inspect the shaft closely. As you can see here there is sufficient dirt and other contaminants to prevent a good seal, hence the leak. Clean the piston shaft, then carefully remove the two rubber seals with a small flat blade screw driver or pick to clean underneath.
  • Inspect the shaft closely. As you can see here there is sufficient dirt and other contaminants to prevent a good seal, hence the leak.
  • Clean the piston shaft, then carefully remove the two rubber seals with a small flat blade screw driver or pick to clean underneath.
  • Re-install the seals on the shaft.
  • Lubricate the shaft with a silicone grease that is safe on rubber.
Hier Übersetzung einfügen
