Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Use your fingernails to carefully pull the ZIF cable lock away from its socket. Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop. Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
  • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
  • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Hier Übersetzung einfügen
